Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector. Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
  • Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
  • Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
  • Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
Hier Übersetzung einfügen
