Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
If your door has an inner liner or panel like this one does it is easy to remove Locate the bolts around the edges of the panel and unscrew them to remove the final barrier between you and the actuator. Or, if you have a plastic or fabric liner slowly peel it back, being careful not to tear it, until it is out of the way.
  • If your door has an inner liner or panel like this one does it is easy to remove
  • Locate the bolts around the edges of the panel and unscrew them to remove the final barrier between you and the actuator. Or, if you have a plastic or fabric liner slowly peel it back, being careful not to tear it, until it is out of the way.
Hier Übersetzung einfügen
