Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
After locating the door lock actuator, which will be on the top or bottom of the door furthest from the engine bay, unplug the single socket running to it by depressing the tab and pulling it away from the motor. As shown in the third image there is an eye hole where your door lock rod will be running through. This will need to be pulled out from the actuator as well As shown in the third image there is an eye hole where your door lock rod will be running through. This will need to be pulled out from the actuator as well
  • After locating the door lock actuator, which will be on the top or bottom of the door furthest from the engine bay, unplug the single socket running to it by depressing the tab and pulling it away from the motor.
  • As shown in the third image there is an eye hole where your door lock rod will be running through. This will need to be pulled out from the actuator as well
Hier Übersetzung einfügen
