Zum Hauptinhalt wechseln
iPad Mini CDMA LCD Assembly Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 42 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7
iPad Mini CDMA LCD Assembly Replacement: Schritt 0, Bild 1 von 2 iPad Mini CDMA LCD Assembly Replacement: Schritt 0, Bild 2 von 2
  • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
  • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
  • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
Hier Übersetzung einfügen
