Zum Hauptinhalt wechseln
iPad Mini CDMA LCD Assembly Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 42 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 10
iPad Mini CDMA LCD Assembly Replacement: Schritt 0, Bild 1 von 3 iPad Mini CDMA LCD Assembly Replacement: Schritt 0, Bild 2 von 3 iPad Mini CDMA LCD Assembly Replacement: Schritt 0, Bild 3 von 3
  • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
  • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
  • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
Hier Übersetzung einfügen
