Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Gently heat the top of the phone to soften the adhesive. Use a suction cup to lift the display and insert opening picks.
  • Gently heat the top of the phone to soften the adhesive. Use a suction cup to lift the display and insert opening picks.
  • Starting from the top, separate the display from the frame.
  • The display cable is attached to the bottom half the display.
  • There is a thin flexible plastic frame between the main phone frame and the glass. Check if the replacement part has this frame included.
  • For reassembly, B7000 adhesive is recommended over TESA adhesive tape due to the tight tolerances .
Hier Übersetzung einfügen
