Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
If you've already checked different cords for your controller then you are probably already suspecting something wrong with the USB port on your controller.
Troubleshooting
  • If you've already checked different cords for your controller then you are probably already suspecting something wrong with the USB port on your controller.
  • Using a voltmeter set to check continuity, check each pin inside the female USB connector with it's corresponding gold contact on the board.
  • On the board with the connector facing away from you, the 4 gold contacts are to the right of the connector labeled V, G, D+, and D-. With the connector still faced away from you, the pins for the connector are in order 1-5.
  • Pin 1 = V
  • Pin 2 = D-
  • Pin 3 = D+
  • Pin 4 = G
  • Pin 5 = G
Hier Übersetzung einfügen
