Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side. Be gentle when removing the screw cover as it is brittle and will break if forced.
  • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
  • Be gentle when removing the screw cover as it is brittle and will break if forced.
  • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
Hier Übersetzung einfügen
