Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board. Use the small flat head screw driver to gently lift the brown clamp.
  • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
  • Use the small flat head screw driver to gently lift the brown clamp.
  • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
Hier Übersetzung einfügen
