Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
We came overprepared with our Pro Tech Toolkit and its 64 driver bits—we only need one to twirl away these Torx screws and remove the midframe, along with its embedded earpiece speaker. On our way to the battery, we fold aside a couple of golden flex cables for the Active Edge sensors. In Pixels past, these cables were routed under the battery, out of sight and easy to destroy with wayward prying. It's nice to see them out of harm's way here. Onward to battery extraction, where two adhesive strips stand in the way. We locate the pull tabs and they cooperate without much fuss. Success! The battery is out.
  • We came overprepared with our Pro Tech Toolkit and its 64 driver bits—we only need one to twirl away these Torx screws and remove the midframe, along with its embedded earpiece speaker.
  • On our way to the battery, we fold aside a couple of golden flex cables for the Active Edge sensors. In Pixels past, these cables were routed under the battery, out of sight and easy to destroy with wayward prying. It's nice to see them out of harm's way here.
  • Onward to battery extraction, where two adhesive strips stand in the way. We locate the pull tabs and they cooperate without much fuss. Success! The battery is out.
  • This battery beats out the Pixel 3's 11.2 Wh battery with its own 11.55 Wh (3.85 V, 3000 mAh) powerhouse. That falls neatly between the iPhone XR and Samsung Galaxy S10e, at 11.16 Wh and 11.94 Wh, respectively.
Wir waren mit unserem Pro Tech Toolkit und seinen 64 Bits viel zu gut vorbereitet — wir brauchten nur ein einziges Bit, um diese Torx Schrauben rauszudrehen und den Mittelrahmen zusammen mit dem darin eingebauten Ohrhörer-Lautsprecher zu entfernen.
Auf dem Weg zum Akku, bogen wir einige goldfarbene Flachbandkabel für die Active Edge Sensoren aus dem Weg. In früheren Pixel-Modellen wurden diese Kabel unter dem Akku entlang geführt, so waren sie nicht zu sehen und waren daher bei zu starkem Hebeln leicht zu beschädigen. Es ist schön, sie an einem so ungefährlichen Platz so zu sehen.
Auf dem Weg zum Akkuausbau stehen uns noch zwei Klebestreifen im Weg. Wir finden die Zuglaschen, die sehr kooperationsfreudig sind und keinerlei Ärger machen. Erfolg! Der Akku ist draußen.
Dieser Akku schlägt den 11,2 Wh Akku des Pixel 3 mit seinen 11,55 Wh (3.85 V, 3000 mAh). Das passt genau zwischen das iPhone XR und dem Samsung Galaxy S10e, mit jeweils 11,16 Wh and 11,94 Wh.
