Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 8
At the positions marked with arrows the LCD-backlight is connected with the power supply. You can now cut the two small wires with an edge cutter or disconnect it carefully from the pins with the soldering iron.
Cutting the wire for the LCD-backlight 2/3
  • At the positions marked with arrows the LCD-backlight is connected with the power supply. You can now cut the two small wires with an edge cutter or disconnect it carefully from the pins with the soldering iron.
Hier Übersetzung einfügen
