Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
The trackpad foam seems higher quality and easier to peel off the trackpad, while still allowing disconnection of the cables without removing the foam itself.
  • The trackpad foam seems higher quality and easier to peel off the trackpad, while still allowing disconnection of the cables without removing the foam itself.
  • The trackpad is replaced as a single unit, so you don't need to remove the foam to do a replacement—unless your replacement part doesn't come with the foam. Then, it must be peeled off. Some damage is likely but not dire.
  • The fact that the frame is soldered to the trackpad probably doesn't increase the cost too much, which is good.
Hier Übersetzung einfügen
