Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 11
The cable cover on the display assembly is secured with plastic clips and is easy to remove. The hinges can be removed independently once the cable cover is removed. The bezel is secured with adhesive and some plastic clips. While the seam allowances seem tight, a plastic prying tool can lift the bezel without causing damage.
  • The cable cover on the display assembly is secured with plastic clips and is easy to remove.
  • The hinges can be removed independently once the cable cover is removed.
  • The bezel is secured with adhesive and some plastic clips. While the seam allowances seem tight, a plastic prying tool can lift the bezel without causing damage.
  • The screen is secured with four standard screws and comes out freely.
  • The display antennas and front-sensor array (including microphone and camera) are the remaining components in the display case.
  • Since the cables route through the display hinge, they may experience stress from repeated flexing, necessitating replacement.
  • They will need to be peeled up off their adhesives, and the various foil tapes will also need to be replaced without deformation, complicating repair.
Hier Übersetzung einfügen
