Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 16
The USB board is easiest to remove first. Take out the screw and lift right up. One screw holds the charging port in. The tricky part is the metal holding it in.
Step 12: Remaining Electronics in the chassis
  • The USB board is easiest to remove first. Take out the screw and lift right up.
  • One screw holds the charging port in. The tricky part is the metal holding it in.
  • After removing the screw, you have to kind of lift the metal up to pull the charging port out.
Hier Übersetzung einfügen
