Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 18
First thing to remove are the speakers. There are two screws holding them in place. The speaker cable is threaded through an opening in the hinge, so it may be a little tricky to remove. Just be patient, take your time, and look around at the other cables in the hinge to find a way to safely wiggle it out.
Step 14: Removing components in assembly
  • First thing to remove are the speakers. There are two screws holding them in place.
  • The speaker cable is threaded through an opening in the hinge, so it may be a little tricky to remove. Just be patient, take your time, and look around at the other cables in the hinge to find a way to safely wiggle it out.
  • Next, I found it easiest to remove the network (wifi) cables. They are easily removed; they just have to be lifted carefully along the lines indicated.
  • The green antenna at the top is held down, so it may be helpful to use a standard screwdriver or something else small and thin to slip under it and lift it up.
Hier Übersetzung einfügen
