Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the battery
Disassembly
  • Remove the battery
  • Get a container to hold all the screws you will be removing. There are many!
  • Remove the 6 screws that hold the battery box in place. Use a marking pen to indicate the colors of the 3 wires connected to the battery box. (red, blue, black)
  • Disconnect the ribbon cable from the bottom of the control panel where the headlight switch and warning lamps are located.
  • Turn the mower on its side and remove the blade.
  • Remove all the screws from the bottom panel of the mower.
  • Remove the height adjustment knob
  • Remove the top cover. If it isn't coming off, check to see if you've removed all the screws.
Hier Übersetzung einfügen
