Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 3
Once the casing has been split/cut apart, you should be able to pull off the section on the connector side.
Remove casing
  • Once the casing has been split/cut apart, you should be able to pull off the section on the connector side.
  • The white rubber seal/gasket will probably come off, but this can be quite easily pushed back into place if needed.
  • The section of casing on the cable side is harder to remove. Use the tip of the utility knife, or better still, a scalpel, to cut and pry it away from the main body.
Hier Übersetzung einfügen
