Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Slide the plastic opening tool from corner to open the top assembly. Be careful with the silicone vapour pipe on opening. You can also push the pipe head into the hole before opening as it is soft silicone material. Be careful with the silicone vapour pipe on opening. You can also push the pipe head into the hole before opening as it is soft silicone material.
Detach top assembly.
  • Slide the plastic opening tool from corner to open the top assembly.
  • Be careful with the silicone vapour pipe on opening. You can also push the pipe head into the hole before opening as it is soft silicone material.
Hier Übersetzung einfügen
