Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 9
The thermal cutoff fuse (SF169E, 172°C, 120V 15A) is crimped with copper beads. You can try to loosen the bead and rotate the thermal cutoff fuse to pull it out. Crimp new thermal cutoff fuse and try to rotate and pull to test if its secure enough.
Replacing thermal cutoff fuse.
  • The thermal cutoff fuse (SF169E, 172°C, 120V 15A) is crimped with copper beads.
  • You can try to loosen the bead and rotate the thermal cutoff fuse to pull it out.
  • Crimp new thermal cutoff fuse and try to rotate and pull to test if its secure enough.
Hier Übersetzung einfügen
