Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 10
Measure the resistance of the new thermal cutoff fuse. The reading should be zero. Secure the thermal cutoff fuse and use touch or flash light to make sure it's centred on the bracket. You might need a plier to hold the nut as it's not fixed inside. Secure the thermal cutoff fuse and use touch or flash light to make sure it's centred on the bracket. You might need a plier to hold the nut as it's not fixed inside.
Test and secure the thermal cutoff fuse.
  • Measure the resistance of the new thermal cutoff fuse. The reading should be zero.
  • Secure the thermal cutoff fuse and use touch or flash light to make sure it's centred on the bracket. You might need a plier to hold the nut as it's not fixed inside.
Hier Übersetzung einfügen
