Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 19
Use a pair of tweezers to pull the headphone jack out of its recess and remove it. The adhesive that holds the headphone jack in place is a bit sticky. In case you can't manage to remove the headphone jack insert a spudger into the jack to help levering it out or apply some more heat to further soften the adhesive. The adhesive that holds the headphone jack in place is a bit sticky. In case you can't manage to remove the headphone jack insert a spudger into the jack to help levering it out or apply some more heat to further soften the adhesive.
  • Use a pair of tweezers to pull the headphone jack out of its recess and remove it.
  • The adhesive that holds the headphone jack in place is a bit sticky. In case you can't manage to remove the headphone jack insert a spudger into the jack to help levering it out or apply some more heat to further soften the adhesive.
Hier Übersetzung einfügen
