Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 23
Use the same procedure to loosen the gray plastic cover below the previous one. Do not remove the cover—it is adhered to the flex cable. Avoid damaging the main flex cable during the following process. Carefully pull up the the cover until it is freed and not blocked by the midframe.
  • Use the same procedure to loosen the gray plastic cover below the previous one.
  • Do not remove the cover—it is adhered to the flex cable. Avoid damaging the main flex cable during the following process.
  • Carefully pull up the the cover until it is freed and not blocked by the midframe.
Hier Übersetzung einfügen
