Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Once the analogue stick has been cleaned, you may wipe the connection points of the D-pad and Action Keys from the PSP to the faceplate. Next, with the faceplate turned upside down, locate the clear/white rubber backing of the D-pad to the left of the display window. Gently peel back and proceed to remove the directional buttons from the faceplate.
  • Once the analogue stick has been cleaned, you may wipe the connection points of the D-pad and Action Keys from the PSP to the faceplate.
  • Next, with the faceplate turned upside down, locate the clear/white rubber backing of the D-pad to the left of the display window.
  • Gently peel back and proceed to remove the directional buttons from the faceplate.
  • Now is the time to clean the rubber backing and D-pad with rubbing alcohol, being sure to remove as much dirt and dust as possible.
Hier Übersetzung einfügen
