Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 9
With the battery dangling to one side, we keep digging. This clear plastic brace kept the driver in place, until we pulled on it too hard. Next, the star of this 'Pod—the (relatively) large driver, which lifts out to give us a peek at the microphone that listens to the inside of your ear. Apple uses this mic to actively adjust the levels of whatever you're listening to (like in the HomePod), and to determine whether or not your tips are fitting correctly.
  • With the battery dangling to one side, we keep digging. This clear plastic brace kept the driver in place, until we pulled on it too hard.
  • Next, the star of this 'Pod—the (relatively) large driver, which lifts out to give us a peek at the microphone that listens to the inside of your ear.
  • Apple uses this mic to actively adjust the levels of whatever you're listening to (like in the HomePod), and to determine whether or not your tips are fitting correctly.
  • This driver might be called the driver, but the one actually doing the real driving is the voice coil.
  • In principle, these work like any other speaker. Current creates an electromagnetic field in the coil, which moves the speaker cone to pump those sick beats into your ears. It also creates the "anti-noise" to cancel out any anti-sick ambient noise.
Während der Akku an der einen Seite herunterbaumelt, buddeln wir weiter. Diese durchsichtige Plastikhalterung hat den Treiber befestigt, bevor wir etwas zu fest daran gezogen haben.
Als nächstes ist der Star dieser Pods an der Reihe: der (relativ) große Treiber. Wir heben ihn heraus und können das Mikrofon erspähen, das auf das Innere deines Ohrs hört.
Apple nutzt dieses Mikrofon, um aktiv die Pegel dessen, was du hörst, anzupassen (wie beim HomePod), und um zu ermitteln, ob deine Tips richtig sitzen oder nicht.
Dieser Treiber nennt sich vielleicht Treiber, aber die tatsächliche Arbeit leistet die Schwingspule.
Im Prinzip funktionieren sie wie jeder andere Lautsprecher. Elektrischer Strom erzeugt ein elektromagnetisches Feld in der Spule, das die Lautsprechermembran bewegt, was den Ton zu deinem Ohr leitet. Er erzeugt auch den "Antischall", um störende Umgebungsgeräusche auszuschalten.
