Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
  • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
  • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
  • Lift up on the blue tab to release the ribbon cable.
Drehe das Gerät so, dass die Frontplatte rechts ist und das Flachbandkabel sichtbar wird.
Ziehe an der blauen Lasche um das Kabel zu lösen.
[* black] Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
+[* black] The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
[* black] Lift up on the blue tab to release the ribbon cable.
