Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use a pair of snap ring pliers to compress the retaining ring inside the driver and remove it from the sanding disc. It may help to use a small flathead screwdriver to pry out the retaining ring as you remove it. It may help to use a small flathead screwdriver to pry out the retaining ring as you remove it.
Remove the sanding disc bearing
  • Use a pair of snap ring pliers to compress the retaining ring inside the driver and remove it from the sanding disc.
  • It may help to use a small flathead screwdriver to pry out the retaining ring as you remove it.
Hier Übersetzung einfügen
