Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 7
The feet are held in place with just one screw each—although the screws themselves are buried deep in slots in the space frame pillars, making them a bit awkward to access. We make do with a 4 mm hex key and a Mako driver for extra leverage. The screws are held captive inside the frame, so you won't lose those, but we can't say the same for these feet. Better keep an eye on these things so they don't run away. We didn't shell out the $400 for the wheel-y upgrade, so it's nice to know that we don't really need to drag this thing to the Apple store to swap its shoes.
  • The feet are held in place with just one screw each—although the screws themselves are buried deep in slots in the space frame pillars, making them a bit awkward to access. We make do with a 4 mm hex key and a Mako driver for extra leverage.
  • The screws are held captive inside the frame, so you won't lose those, but we can't say the same for these feet. Better keep an eye on these things so they don't run away.
  • We didn't shell out the $400 for the wheel-y upgrade, so it's nice to know that we don't really need to drag this thing to the Apple store to swap its shoes.
  • If you're feeling adventurous and want to attach your own feet or wheels, the screws are M5x0.8. Since we can't remove them, we're unsure of their exact length, but we estimate 15-20 mm. They extend out about 4-4.5 mm from the bottom of the aluminum slab.
Die Füße werden von jeweils nur einer Schraube festgehalten - aber die Schrauben befinden sich in Vertiefungen in den Gitterrahmensäulen, was es ein wenig umständlich macht, an sie heranzukommen. Wir bewerkstelligen das mit einem 4 mm Inbusschlüssel und einem Mako-Griffstück für extra Drehmoment.
Die Schrauben verbleiben im Rahmen, du wirst sie also nicht verlieren. Bei den Füßen sieht das anders aus. Die solltest du im Auge behalten, damit sie nicht abhauen.
Wir haben keine 400 Dollar für das Rollen-Upgrade hingelegt, also ist es ganz schön, zu wissen, dass wir das Ding nicht wirklich in den Apple Store schleifen müssen, um seine Füße auszutauschen.
Wenn du ein wenig abenteuerlustig bist und eigene Füße oder Rollen anbringen möchtest: es handelt sich um M5x0,8 Schrauben. Da wir sie nicht ganz entfernen konnten, kennen wir auch nicht ihre exakte Länge, schätzen aber so 15 - 20 mm. Sie ragen 4 - 4,5 mm aus der Unterseite der Aluminiumplatte heraus.
