Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 4
Slide the tool all along the right edge of the phone to slice through the adhesive securing the display. If you plan to reuse the display, continue moving the tool in a straight line as you approach the corners of the phone—do not round the corners with the tool. The corners of the LCD come very close to the edge of the digitizer and are easy to damage. If you plan to reuse the display, continue moving the tool in a straight line as you approach the corners of the phone—do not round the corners with the tool. The corners of the LCD come very close to the edge of the digitizer and are easy to damage.
  • Slide the tool all along the right edge of the phone to slice through the adhesive securing the display.
  • If you plan to reuse the display, continue moving the tool in a straight line as you approach the corners of the phone—do not round the corners with the tool. The corners of the LCD come very close to the edge of the digitizer and are easy to damage.
Schiebe dein Werkzeug an der gesamten rechten Kante entlang, um den Kleber zu lösen.
Wenn du das Display wiederverwenden willst, ziehe das Werkzeug gerade weiter, wenn du an die Ecken kommst - gehe mit dem Werkzeug nicht um die Ecke. Das LCD ist hier sehr empfindlich.
