Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Cut the plastic from the shell, aligned with red markers. Use a cutter to cut the big pieces of plastic. Use the cutter again to cut some plastic from the shell. This is required for the LCD to fit properly.
  • Cut the plastic from the shell, aligned with red markers.
  • Use a cutter to cut the big pieces of plastic.
  • Use the cutter again to cut some plastic from the shell. This is required for the LCD to fit properly.
  • Only cut the plastic that sticks out! It's possible that the red markers are not 100% accurate.
  • First things first, there are 2 GBA models. 32 pin motherboards and 40 pin motherboards, before you order anything, make sure which model you have. The GBA's starting with a 0 is a 40 pin, if it start with a 1 it's a 32 pin. Please advise Google if you are not sure which model you have.
Hier Übersetzung einfügen
