Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Pull the drive pad bearing straight off of the motor shaft. You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing. You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing.
  • Pull the drive pad bearing straight off of the motor shaft.
  • You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing.
Hier Übersetzung einfügen
