Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Starting at the outside edge of the battery, use the flat edge of a spudger to separate the battery from the rear of the device. Work carefully. Excessive force on battery may cause it to bend, break, or crack. Move the spudger along each side of the battery, prying upwards with even pressure.
  • Starting at the outside edge of the battery, use the flat edge of a spudger to separate the battery from the rear of the device.
  • Work carefully. Excessive force on battery may cause it to bend, break, or crack.
  • Move the spudger along each side of the battery, prying upwards with even pressure.
  • As the adhesive releases, push the spudger further underneath the battery.
  • Once half of the battery is detached, pry the other half in the same manner.
  • Remove the battery assembly from the Kindle.
Hier Übersetzung einfügen
