Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
The rear half of the enclosure is bolted to the handle support, so the front half will be removed first. Pull the front half of the enclosure straight away from the rear half to separate the enclosure. If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
  • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
  • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
  • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
  • Remove the front half of the handle enclosure.
Hier Übersetzung einfügen
