Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
For repairs such as battery replacement you only need to remove the PCB from the top component This PCB is held on by two plastic tabs. Which are marked in red. In the second image you can see how the upper case looks  after removing the PCB
Pulling the PCB out
  • For repairs such as battery replacement you only need to remove the PCB from the top component
  • This PCB is held on by two plastic tabs. Which are marked in red.
  • In the second image you can see how the upper case looks after removing the PCB
  • In order to remove the PCB you will need to use your fingers to push the case from the inside outside. And another finger to push from the top
  • The PCB will come out one side first. Place your Halberd Spudger on the lifted side to keep in there
  • Then with the Spudger tip push the rest out
Hier Übersetzung einfügen
