Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 8
Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive. Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off. Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
  • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
Löse mit einem T15 Torx-Schraubendreher die vier 3,37 mm Schrauben aus beiden Seiten der Festplatte.
Entferne das Kunststoffgehäuse von der Festplatte. Es ist mit Klemmen fixiert, aber es sollte sich leicht lösen lassen.
