Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged. Do not use any metal tools to pry open the device. It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
  • Do not use any metal tools to pry open the device.
  • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
Hier Übersetzung einfügen
