Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
Schritt 5
Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard. Remove the battery from the case. Remove the battery from the case.
  • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
  • Remove the battery from the case.
Hier Übersetzung einfügen
