Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Be sure to power off and unplug your device before you begin your repair. Orient the laptop so that it is bottom up, and the track pad is closest to you.
  • Be sure to power off and unplug your device before you begin your repair.
  • Orient the laptop so that it is bottom up, and the track pad is closest to you.
  • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen, but will stay attached to the cover.
  • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  • The cover should easily come off.
Hier Übersetzung einfügen
