Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2
Carefully insert an opening pick under the bottom of the battery. You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery. If the battery begins bend out of shape, apply more heat or isopropyl alcohol and pry slower. Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  • Carefully insert an opening pick under the bottom of the battery.
  • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery. If the battery begins bend out of shape, apply more heat or isopropyl alcohol and pry slower.
  • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  • Gradually push the pick further under the battery to pry up the bottom edge.
  • Do not insert the pick more that ~1.5 cm past the edge of the battery to avoid damaging the daughterboard and display ribbon cables.
  • Slide the pick all along the bottom edge to release the bottom of the battery.
Schiebe vorsichtig ein Plektrum unter das untere Ende des Akkus.
Vielleicht musst den iOpener öfter einsetzen, um den Kleber zu lösen. Der Kleber ist sehr stark und du könntest mehrere Versuche brauchen, um das Plektrum einzusetzen. Wenn der Akku sich verformt, nutze mehr Hitze oder Isopropylalkohol und heble langsamer.
Gib dein Bestes, damit der Akku sich nicht verformt. Aus weichen Lithium-Ionen-Akkus können Chemikalien auslaufen, sie können Feuer fangen oder sogar explodieren, wenn sie beschädigt werden.
Drücke das Plektrum Stück für Stück unter den Akku, um die untere Kante hochzuhebeln.
Schiebe das Plektrum nicht tiefer als etwa 1,5 cm unter die Kante des Akkus, damit die Displaykabel und das Daughterboard nicht beschädigt werden.
Schiebe das Plektrum an der ganzen unteren Kante entlang, um das untere Ende des Akkus zu lösen.
