Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The momentary-type power switch is located on the left side rear of the ventilator along the bottom edge. Press the power switch once. A message appears in the screen that prompts you to Press Accept to Shutdown or Press Cancel to Ignore. Pressing the Accept button will power off the ventilator.
shut down the ventilator
  • The momentary-type power switch is located on the left side rear of the ventilator along the bottom edge. Press the power switch once.
  • A message appears in the screen that prompts you to Press Accept to Shutdown or Press Cancel to Ignore.
  • Pressing the Accept button will power off the ventilator.
  • Pressing Cancel will return the ventilator to its previous state.
  • Press Alarm Silence to silence the Shut Down alarm.
Hier Übersetzung einfügen
