Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 2
Use the flat end of a spudger to pry up and disconnect the charging port and display flex cables from the daughterboard. Use the flat end of a spudger to pry up and disconnect the charging port and display flex cables from the daughterboard. Use the flat end of a spudger to pry up and disconnect the charging port and display flex cables from the daughterboard.
  • Use the flat end of a spudger to pry up and disconnect the charging port and display flex cables from the daughterboard.
Heble das Flachbandkabel zur Ladebuchse und das Display-Flachbandkabel mit dem flachen Ende des Spudgers von der Tochterplatine hoch und trenne sie ab.
