Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Use the biggest wall wart you have lying around. I had a 12 volt, 2.5 amp one that used to power a router, so I used that. Take a pair of wire strippers, cut the plug off, and strip the two wires. Make sure you know which end is positive and which end is negative. The stripped wire ends.
The Wall Wart
  • Use the biggest wall wart you have lying around. I had a 12 volt, 2.5 amp one that used to power a router, so I used that.
  • Take a pair of wire strippers, cut the plug off, and strip the two wires. Make sure you know which end is positive and which end is negative.
  • The stripped wire ends.
Hier Übersetzung einfügen
