Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7
Use a pair of tweezers to peel the new Force Touch gasket off the see-through backing film. Make sure you peel off the Force Touch gasket with both protective foils attached to it. Peel off the protective foil from the bottom side of the Force Touch gasket. The bottom side is where the Force Touch connector faces. Peel off the protective foil from the bottom side of the Force Touch gasket. The bottom side is where the Force Touch connector faces.
  • Use a pair of tweezers to peel the new Force Touch gasket off the see-through backing film. Make sure you peel off the Force Touch gasket with both protective foils attached to it.
  • Peel off the protective foil from the bottom side of the Force Touch gasket. The bottom side is where the Force Touch connector faces.
Hier Übersetzung einfügen
