Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Slide the opening pick along the edge of the battery to loosen the adhesive. The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive.  Apply the iOpener for at least two minutes. Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Slide the opening pick along the edge of the battery to loosen the adhesive.
  • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
  • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
  • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
  • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
Schiebe das Plektrum an der Kante des Akkus entlang, um den Kleber abzulösen.
Der Kleber, mit dem der Akku befestigt ist, ist weich. Wenn du allerdings Schwierigkeiten hast den Akku herauszuhebeln, kannst du einen erwärmten iOpener auf die Rückseite der Uhr legen, um den Kleber aufzuweichen. Lasse den iOpenenr mindestens zwei Minuten lang einwirken.
Heble den Akku langsam und mit stetigem Druck heraus, und löse ihn von dem Kleber ab, mit dem er an der Systemplatine befestigt ist.
Achte auf die Displaykabel und vor allem das Force Touch Kabel, das in einer Ecke den Akku bedeckt, um zu vermeiden, dass sie beschädigt werden, während du den Akku heraushebelst.
Achte darauf, den Akku nicht zu beschädigen oder zu verformen, da er sich sonst entzünden oder explodieren kann.
Versuche nicht, den Akku schon ganz zu entfernen, er ist immer noch mit der Uhr verbunden.
