Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the metal shield from the iPad. Use max heat and max air on your hot air station for this step ONLY. Move the nozzle around the edge of the cover to flow the solder holding it to the logic board.
  • Remove the metal shield from the iPad.
  • Use max heat and max air on your hot air station for this step ONLY. Move the nozzle around the edge of the cover to flow the solder holding it to the logic board.
  • Lift straight up so that the logic board is slightly hovering from the desktop. The logic board will drop down once the solder flows.
  • Hot air is hot! Most hot air stations can reach 500ºC (900ºF). Wear the appropriate personal protective equipment.
Hier Übersetzung einfügen
