Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Carefully peel off the protective cloth which covers the inside of the earcup. The protective cloth is held in place by mild adhesive. If the cloth starts to rip during the removal, apply an heated iOpener to the cloth or use a hairdryer/heatgun at the lowest setting to loosen the adhesive. The protective cloth is held in place by mild adhesive. If the cloth starts to rip during the removal, apply an heated iOpener to the cloth or use a hairdryer/heatgun at the lowest setting to loosen the adhesive.
  • Carefully peel off the protective cloth which covers the inside of the earcup.
  • The protective cloth is held in place by mild adhesive. If the cloth starts to rip during the removal, apply an heated iOpener to the cloth or use a hairdryer/heatgun at the lowest setting to loosen the adhesive.
Ziehe den Schutzfilz, der die Innenseite der Hörmuschel bedeckt, vorsichtig ab.
Der Schutzfilz ist leicht festgeklebt. Wenn das Filz beim Entfernen zu reißen beginnt, lege einen erhitzten iOpener auf den Filz oder verwende einen Föhn/eine Heißluftpistole auf der niedrigsten Stufe, um den Klebstoff zu lösen.
