Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 9
Insert the flat end of a spudger between the battery cover and the battery. Avoid to use the spudger as a lever when working close to the battery. Use to spudger to carefully separate the  plastic cover from the earcup. Avoid excessive force to the battery.
  • Insert the flat end of a spudger between the battery cover and the battery.
  • Avoid to use the spudger as a lever when working close to the battery.
  • Use to spudger to carefully separate the plastic cover from the earcup. Avoid excessive force to the battery.
Setze das flache Ende eines Spudgers zwischen die Akkuabdeckung und den Akku ein.
Vermeide es, den Spudger als Hebel zu verwenden, wenn du im Bereich des Akkus arbeitest.
Verwende einen Spudger, um die Kunststoffabdeckung vorsichtig von der Hörmuschel zu trennen. Vermeide übermäßige Krafteinwirkung auf den Akku.
