Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver Remove the back connector strip using a wedge device to pry it off of the device With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
  • Remove the back connector strip using a wedge device to pry it off of the device
  • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
Hier Übersetzung einfügen
