Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
As with most phones, the screws are the first to go once we're inside. And our Essential Electronics Toolkit is here, ready and waiting to take them out. Despite their other non-repair-friendly tendencies, one thing Galaxy phones always score points for are the standard Phillips #00 screws. A few extremely tight midframe screws later, here's our first good look inside (in the visible-light spectrum, anyway).
  • As with most phones, the screws are the first to go once we're inside. And our Essential Electronics Toolkit is here, ready and waiting to take them out.
  • Despite their other non-repair-friendly tendencies, one thing Galaxy phones always score points for are the standard Phillips #00 screws.
  • A few extremely tight midframe screws later, here's our first good look inside (in the visible-light spectrum, anyway).
  • Each phone gets its earpiece speaker mounted to the upper antenna assembly, which contains a dedicated speaker enclosure—that's a first! The speaker is the rectangular bit framed with a bright red gasket. It still fires through a channel in the midframe, much like it did on the Note10 and S20—but the new larger enclosures ought to boost audio quality a bit.
  • Both phones also get a rear-facing mic that piggybacks directly onto the back cover. Thankfully they connect via repair-friendly spring contacts, which is why we didn't encounter any booby traps opening these things up.
Wie bei den meisten Smartphones müssen erstmal die Schrauben dran glauben. Dank unseres Essential Electronics Toolkit ist das gar kein Problem.
Obwohl Samsung es uns in vielerlei Hinsicht schwer macht, ihre Telefone zu Reparieren, freuen wir uns jedes Mal über die normalen #00 Kreuzschlitzschrauben, die sie verbauen.
Nach ein paar extrem festen Schrauben am Mittelrahmen können wir einen ersten guten Blick in das Innere der Telefone werfen (zumindest auf das, was innerhalb des sichtbaren Lichtspektrums liegt).
Bei beiden Handys sitzt der Ohrhörerlautsprecher an der oberen Antenneneinheit, aber erstmals mit eigenem Gehäuse! Das hellrot umrahmten Viereck. Der Sound wird immer noch durch einen Kanal im Mittelrahmen geleitet, ähnlich wie beim Note10 und beim S20. Aber die größeren Gehäuse dürften für eine leicht verbesserte Audioqualität sorgen.
Beide Smartphones haben ein rückwärtiges Mikrofon, dass direkt in der Rückabdeckung sitzt. Zum Glück sind sie mit Federkontakten versehen, deshalb sind wir auch nicht über Kabel gestolpert.
