Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
Next up: cameras. Both motherboards have to come out first. These two camera arrays differ mainly in how they zoom, and how many pixels they pack: The Ultra inherits the super-cool optical Space Zoom   module from the S20 Ultra, but with a smaller 12 MP sensor behind it. (Click the link for a detailed take-apart of the periscope mechanism.) The regular Note 20 doesn't "space zoom," instead relying on a dense 64 MP sensor and some cropping magic.
  • Next up: cameras. Both motherboards have to come out first.
  • These two camera arrays differ mainly in how they zoom, and how many pixels they pack:
  • The Ultra inherits the super-cool optical Space Zoom module from the S20 Ultra, but with a smaller 12 MP sensor behind it. (Click the link for a detailed take-apart of the periscope mechanism.) The regular Note 20 doesn't "space zoom," instead relying on a dense 64 MP sensor and some cropping magic.
  • The situation reverses for the wide-angle module, where the Ultra gets a gigantic 108 MP sensor—which, like the S20 Ultra, usually bins down to 12 MP. Meanwhile, the regular Note packs a more modest 12 MP sensor here.
  • Neither Note gets the S20 Ultra's 40 MP front-facing camera—instead, both pack 10 MP selfie sensors, which appear to come bundled with some unfortunate smoothing effects.
  • Oddly, the standard Note 20 releases its selfie module with gentle prying—but the Ultra's comes firmly hot-glued in place.
Weiter mit den Kameras. Dafür müssen zuerst die Motherboards raus.
Diese beiden Kameragruppen unterscheiden sich sehr, was Zoom und Pixel angehen:
Im Ultra sitzt das supercoole optische Space Zoom Modul aus dem S20 Ultra, aber mit einem kleineren 12 MP Sensor. (Im Link findest du mehr Bilder und Infos über den Periskopmechanismus.) Das normale Note20 hat keinen "Space Zoom", sondern einen sehr dicht bepackten 64 MP Sensor und gute Bearbeitungssoftware.
Beim Weitwinkelobjektiv ist es andersherum. Das Ultra hat einen 108 MP Sensor, der wie beim S20 Ultra auf 12 MP runtergebinnt wird. Das normale Note hat einen viel gewöhnlicheren 12 MP Sensor.
Keines der beiden Note hat die 40 MP Frontkamera des S20 Ultra erhalten. Beide nutzen 10 MP Selfie-Sensoren, die scheinbar mit ein paar unglücklichen Glättungseffekten ausgestattet sind.
Komisch, beim normalen Note20 löst sich das Selfie-Modul durch leichtes Hebeln. Beim Ultra ist das Modul richtig festgeklebt.
