Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Peel the wireless charging coil off the battery starting with the left side. The adhesive is weak but you can use an opening pick to cut it if necessary. During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
  • Peel the wireless charging coil off the battery starting with the left side.
  • The adhesive is weak but you can use an opening pick to cut it if necessary.
  • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
Hier Übersetzung einfügen
